Results 1 to 5 of 5
Thread: Coolant temp sensor thread size and pitch
    Veteran slide86's Avatar
    Huw
    Hills
    Default Coolant temp sensor thread size and pitch
    I just need to buy an adaptor for my gauge
    I need to know the thread pitch and size for the sensor that is in the water neck on the FRONT of the engine, not the rear.
    My thread taps arent the correct size........
    Moderator Sam-Q's Avatar
    Endeavour Hills
    dash temp? 3/8" BSP NPT, shit of a thing to tap. From my experience you only need to wind the tap in one third of the depth with a 14.5mm hole. I can do it for you if you like just throw me $10 and post and I am happy
    Huw
    Hills
    yeah for dash temp
    im trying to buy an adaptor to fit my autometer sender in there..........the ones in the kit are far too big (1/2 im pretty sure)
    Jonathan
    From memory the aftermarket temp sensors are 3/8" NPT tapered thread.
    The Toyota temp sensors are 3/8" BSP tapered thread. Both LOOK the same, small difference.
    (I could have this backwards)
    Endeavour Hills
    yes backwards, only one extra thread per inch
  1. 4age intake air sensor thread size?
    By Wyma in forum Technical - Questions
    Last Post: 18th April 2012, 09:46 PM
  2. thread pitch
    By gooza in forum Technical - Rims & Tyres
    Last Post: 12th November 2011, 08:30 AM
  3. Coolant temp trims. Tuner guys, Help!
    By Skylar in forum Technical - Questions
    Last Post: 14th June 2011, 03:16 PM
  4. Coolant/water temp sensor missing. Need to block the radiator!
    By crackett in forum Technical - Questions
    Last Post: 23rd March 2009, 12:27 AM
  5. 4age Oil pressure sensor thread size?
    By eightsixboy in forum Technical - Questions
    Last Post: 9th September 2008, 08:30 AM
