You could try and run a new 12v ignition wire to the positive on the coil, or just ghetto rig a wire from your battery to the positive temporarily to test if its a wiring issue.
Otherwise it could be dead.
Car - ke70
motor - 4age
use - daily
problem - theres no spark and checked with a multimeter there absolutely no power at my coil
occurs/started when -last weekend, drove to amates, parked, went outside to head t the hills and it wouldnt fire
personal situation (if applicable)-.......... i wanna drive it
oh yeah i frgot to mention, have tried new coil, changed dizzy initially too to make sure, when i ran a power source to the coil straight off the battery, my circuit opening relay started goin apeshit
Id suggest maybe an earth problem them.
make sure you have a big ass earth strap(or a few) on 4 age, i had issues with mine that turned out to be earth problems,
theres 2 main earths on my motor and the one on the gearbox
blown fuse?
