Results 1 to 5 of 5
Thread: rattler/viper alarm no longer deactivates via alarm pad
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    Default rattler/viper alarm no longer deactivates via alarm pad
    Car - ae86
    motor - 20v
    use - hooning
    problem - alarm system
    occurs/started when - took the car to get painted
    personal situation (if applicable)- thats personal
    ok so, ive got my ae86 and its got a rattler/viper alarm system.
    as of recently the alarm started playing up and wouldnt let me deactivate the alarm but after fking with the pos/negative on the battery it would work.
    now, having just had the car resprayed (the panel beaters removed the positive from the battery) the alarm just goes nuts when you put the positive back on the battery, even if i try and deactivate it with the alarm pad; it does nothing.
    the car is now undrivable due to the immobilizer.
    - i have replaced the battery in the alarm pad hoping that it had just not had enough charge to send the signal to deactivate/active the alarm but that did nothing.
    i really want to drive my ae!!
    any help is appreciated.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    this is a long shot but try and reconect the battery with the ignition in the on possition
    Filip
    Jozzaville
    I did try that and the alarm doesn't go berzerk but, u still can't crank the car and if u nudge the car ie. Sit in it, the alarm goes off again
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    connect the batterie NEGATIVE first, and then, your alarm speaker probaly has a key hole in the back of it, you should have a small kep for it, turn it off and back on again see if it shuts its trap
    Filip
    Jozzaville
    Nahh theres no key hole for it. Im going to take it into an alarm fitting place and let them sort it out as I disconnected the alarm
  1. FREE BEER* (*help me fix/install new viper alarm)
    By matt86 in forum Brisbane & QLD Events and Discussion
    Last Post: 8th September 2010, 12:31 AM
  2. Alarm System Wiring, Few Q's
    By tc-rolla in forum Technical - Questions
    Last Post: 24th March 2010, 07:24 AM
  3. Alarm Systems
    By tc-rolla in forum General Topics (No Technical Questions)
    Last Post: 2nd September 2009, 07:24 PM
  4. Best alarm system for bucks
    Last Post: 16th February 2008, 10:42 AM
  5. alarm for my 86
    By .wolfwood in forum General Topics (No Technical Questions)
    Last Post: 2nd September 2005, 01:23 AM
