Results 1 to 9 of 9
Thread: JDM ADM front caliper seals
    Member grey_nomad's Avatar
    Henk
    Lake Gardens
    Default JDM ADM front caliper seals
    I rebuilt a set of JDM calipers using the better condition pistons that came out of the original ADM calipers. Measured both with micrometer and as far as I could tell they were the same size.
    I fitted a PBR seal kit from the local brake shop to the JDM calipers using the ADM pistons and now I find brake fluid weeping from the seal area. Brakes work fine but there's a definite weep of fluid.
    Should I have used a genuine kit? Some other seal kit?
    Can the ADM pistons be used in the JDM calipers?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    did you lube the seals, with eaither brake grease, or some brake fluid it self??
    Henk
    Lake Gardens
    Yep, with brake rubber seal grease.
    Jonathan
    Then I have a brake piston out, I pollish it up with a wire wheel on the bench grinder. It is hard chromed, and you won't hurt it with the wire wheel. But it's good to take off all the old crap that builds up. Maybe some of this crusty stuff cut the new seal?
    If would seam you have to take the piston out and do it all again.
    Also, try and clean up inside the caliper as much as you can before the new seal goes in. And smother the piston with rubber grease.
    Henk
    Lake Gardens
    Did all that. I am a retired motor technician and have rebuilt countless calipers and have never had this particular problem. Hence my question about piston sizes and seal kits.
    Just looking for confirmation of the piston sizes between the ADM and JDM calipers. If they are identical, then its a sealing problem. And it is happening on both left and right calipers, so it is something common.
    Think I'll grab the genuine Toyota kits from AJPS and redo them.
    Jonathan
    I know PBR clutch masters always leak just a little. I'm not a fan of PBR.
    West
    Just while were on this topic, does anyone have the front and rear piston diameters for ae86 disc brakes? I need this info to do some maths on a possible brake upgrade.
    Veteran timbo's Avatar
    Tim?
    Wild West
    i have some rears lying around in the lockup, so i will have to wait until a weekday before i can have a look.
    Jonathan
    Front brake pistons are 50.8mm
    Rear brake pistons (for disc) are 34.93mm
  1. Replies: 5
    Last Post: 16th November 2012, 07:54 PM
  2. Replies: 1
    Last Post: 3rd July 2012, 09:45 AM
  3. Replies: 1
    Last Post: 7th December 2011, 11:12 PM
  4. WTB: JDM front right caliper
    By svenmate in forum Cars or Parts Wanted
    Last Post: 30th May 2011, 02:58 PM
  5. wtb adm ae86 front caliper bolt
    By cracker in forum Adelaide & SA Events and Discussion
    Last Post: 4th August 2009, 02:56 PM
