pm'd re photos, if you find your cable.
located on gold coast, selling up whats sitting around in shed
$100 - CUSCO 4kg Front springs suit standard struts
$100 - custom king springs 8kg rate 210mm free height
$50 - king springs rears 200mm free length
$75 - ae86 front brake calipers
$50 - ae86 RH front strut tower
$30 - strut tops
$50 - celica or cressida (cant remember) lower control arms (420mm long)
$30 - ae86 castor rods
$30 - ae86 rear swaybar
$50 - ae86 rear swaybar with link pins
$40 - ae86 rear swaybar D bush retainers
$20 - ae86 rear trailing arms 2 lowers 1 upper
$20 - ae86 panard rod
$40 - ae86 steering knuckles
$75 - Flywheel 216mm 8 bolt with bolts
$75 - whiteline rear swaybar 20mm with U bolt diff mounts
$50 - performance wheel 14 x 7 114.3 4 stud, 195/60r14 tyre 6mm tread
$25 - washer bottle with motor
$40 - ae86 overflow bottle with washer bottle
$15 - ae86 overflow bottle
$30 - side rear view mirrors
$40 - T50 shifter only
$20 - each 7mgte 440cc injector
$15 - each 4ac voltage reg or coil
$40 - fwd starter motor with cable
$30 - RWD water pump pulley 5 rib 4ag
$40 - set of 4age 20 valve leads with coil lead
$40 - distibutor cap 4age 20 valve good condition
$40 - bodged up 4age 20 valve ae86 inlet plenum
$150 - silvertop 20 valve block with main caps, pistons with rods and caps - no crank
$100 - 2.5 inch 20 valve exhaust system suit AE82(extractors, flexi, cat, high flow muffler)
$20 - Ae71 washer with coolant overflow bottle
$100 - Camry VZV21 v6 radiator, inlet and outlet rhs measures 700 tall x 440 wide
$20 - AE71 LH headlight
$75 - 2 inch virtually straight through muffler measures 400 x 210
$150 - complete AE92 rear disc brakes with hand brake cables
$20 - 4AC inlet and exhaust manifold
$50 - 4ag - fwd engine mount 4 of came off 20v
$30 - AE71 rear drums/shoes/backing plates
$20 - BOSS 2 channel 320watt amp
$20 - kenwood 6x9 speaker with half enclosure
$20 - GT25/28 air inlet pipe off nissan something rather
$30 - MR2 engine under trays 2 of good condition
$50 - performance wheel 14 x 7 114.3 4 stud, 195/60r14 tyre 6mm tread 20mm positive offset
$100 - pair cheviot 14 x 6 mag wheels 114.3 x 4 stud 20mm positive offset
$200 - set of 14 x 6 3 spoke mag wheels 114.3 x 4 stud 20mm positive offset
i can post some things at buyers exspense
message 0424 173 858 as i don't get on internet very often
thanks for looking
Interested in the cusco springs if you're willing to post to Vic.
i can post via cash on delivery if your interested let me know
Il take the adjustable control arms
pm sent this morning about lca's
updated with photos now, thanks for looking
I'll take the whiteline swaybar, got all bushes and mounting get etc?
I'll send you a msg man.
got a 20 valve block for sale to
pm sent brake calipers
