Results 1 to 5 of 5
Thread: Bolt on 280mm rear discs for U,T,S and F series diffs [SA]
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    Default Bolt on 280mm rear disc setup for U,T,S and F series diffs [SA]
    Hey guys,
    Got a near complete setup here that will bolt to your U,S,T or F diff to give you 280mm disc brakes.
    Includes:
    2xCalipers w/ decent condition pads
    2xBacking plates w/ internal drum handbrake
    2x flexi hoses, with soft to hard line mount
    2x handbrake cables (L/R)
    No rotors, sorry. P/N# PBR 706.
    Chasing $250. Seen them go for more, but this is around what they were purchased for then accumulated the extra bits like the proper flex lines and cables.
    Located in Southern Adelaide, Will post.
    CHEERS
    Ryan
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
    Senior Member Stain's Avatar
    Derek
    Far North
    maybe you should reword your ad
    Ryan
    Southern 'burbs
    Good enough for you now mate?
    Derek
    Far North
    Well, no, not really.
    You're advertising "Bolt on 280mm rear discs" / "to give you 280mm disc brakes" yet your sale does not include the discs!
    At the very least you should "for use with 280mm discs" and give potential buyers the part# of the required disc, as I'm sure you would have looked it up if you were planning on using this setup.
    Ryan
    Southern 'burbs
    There we goooooo
  1. FS: T series with lsd and discs SA
    By Hazzard in forum Car Parts For Sale
    Last Post: 18th August 2011, 11:37 AM
  2. F series, G series, T series 4link diffs ready to bolt in also W58s
    By sumfancyname in forum Car Parts For Sale
    Last Post: 11th August 2011, 09:39 PM
  3. AE86 + E7 rear bolt on flares - SA
    By R&D Mechanical in forum Car Parts For Sale
    Last Post: 20th November 2010, 02:18 PM
  4. New Rear Discs set for T-series JDM 6.7 diff
    By tuned86 in forum Car Parts For Sale
    Last Post: 17th February 2010, 08:39 AM
  5. whats the difference between S series diffs and T series
    By AE86dori in forum Technical - Questions
    Last Post: 27th June 2008, 06:44 PM
