Results 1 to 9 of 9
Thread: First engine start - Why does it make this noise!?
    Senior Member jet111's Avatar
    Mark
    Default First engine start - Why does it make this noise!?
    Ok so after a long awaited time, my engine finally runs in my new shell!
    I had the engine running in a previous car perfectly, no problems, no noises.
    The engine had been sitting around for a while.. Now it makes a high pitched squealing noise, very annoying!
    The rookie question at hand is: why?
    Veteran slide86's Avatar
    Huw
    Hills
    id say its a vacuum leak. does the pitch or volume change when you rev it? check over all small hoses, one could have fallen off or been over looked when installing engine
    Mark
    The pitch doesn't change but its not as noticeable when it is revved
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Sounds like a bearing almost, waterpump or timing belt tensioner.
    Andrew
    Gone
    Joel
    Picton
    crickets?? .....the sound is very metallic, it seems to clean to be a bearing sound (not scratchy enough) it sounds to me like impeller blades are hitting something. its really to hard to say... get yourself a hose put in over your ear and move around the engine.. might help you isolate the source
    Senior Member randomskate's Avatar
    Feb 2011
    Nathan
    Ryde
    remove the alternator belt and see, dont run it for too long though
    BuildAE86\Pix..............SaleParts\SR20 N14
    wtb\smallport 421 headers.
    Mark
    Bingo! Looked over all the hoses tonight.. turns out it was the breather from the back of the rocker cover... One of the biggest hoses on the engine lol.
    I should of double checked everything properly before resorting to a thread. I'm glad there was no problem and she is happily living once again.
    Now sounds like this:
    Sweeeeet!
    Huw
    Hills
    good to hear!
    Feb 2011
    Nathan
    Ryde
    sounds awesome
  1. Kitten Mittons-Does your kitten make TOO MUCH NOISE!
    By McLEVIN in forum Youtube Chan
    Last Post: 29th March 2011, 09:31 PM
  2. rounded lug nut, and engine noise.
    By Ade_Mc in forum Technical - Questions
    Last Post: 25th February 2010, 04:35 PM
  3. engine wont start
    By evil86 in forum Technical - Questions
    Last Post: 4th April 2009, 04:22 PM
  4. weird engine noise! advice opinions please.
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 10:20 PM
  5. knocking/ratteling noise from engine/gearbox..?
    By DRFT - 86 in forum Technical - Questions
    Last Post: 31st January 2007, 04:14 PM
