crazy looking exhaust manifold will be interesting to see how this goes should be good i would imagine
Looks good so far, got room for this though?
adm ae86 now one hell of a project
ae71 small project
this thing is mental !!
Awesome amount of fabrication work you've put into this thing. Very original ideas you're putting into this car. Can't wait to see what the finished build looks like...
Made a stainless intake pipe today, it will be shortened once i get a pod filter
Hi Mate,
Any updates with this?
Looking at perhaps doing a similar conversion. You didn't by any chance knock up a template for that sump you done did you?
Cheers,
Shazza
just read your whole thread mate your an artist! top fab work well done! had a 3rz in my old hilux and went like stink stock..will be ridiculous in a ksev...
Hopefully getting it running this weekend!
Nah I didn't, the guy on rollaclub that put a turbo 3RZ into a KE38 just turned his around and redrilled it making the pick up to suit. Making an alloy one was VERY time consuming! If I was to do it again I would cut the original one in half and turn the bottom half around and weld it back together, but it still would be close to the steering rack mounts. It is a tall engine, I will be modifying the bonnet as I'm not a fan of crossmember spacers, my sump is really small at the rear to get it as low as i could
Made a surge tank, washerbottle, coolant overflow tank and polished the fuel tank Fuel set-up is in and almost finished:
wow, is there going to a be a component on this thing that isn't custom made
With that Intake pipe are you worried about the heat transferring from the extractors?
