ITEM:
KE70 complete manual conversion.
includes K40 gearbox thats been for a swim, but only had a dribble of water in it.
gearbox crossmember
tailshaft, to suit a jap banjo diff, but if you have a borg warner diff, it should be a simple case of swapping rear halves. centre bearing isnt too bad on this tailshaft.
flywheel that needs machining
flywheel bolts
clutch fork
clutch, but i would suggest a new one, this ones pretty well had it. clutches are cheap...
clutch cable with clips
pedal box with pedals
brackets that go from block to gearbox
manual backing plate
all bolts
shifter with bushes
and a partridge in a pear tree
CONDITION:
everything was fine the last time i drove on it.
the car went swimming in the floods, the box, i drained fluids out, only a dribble of water came out, and as we all know, water sits on the bottom so should be good still.
REASON FOR SELLING:
stripped car
PRICE AND PRICE CONDITIONS:
$200
cheap price due to flywheel needing machining and clutch being on last legs, is still a cheap price for the whole conversion, just wanna get this stuff gone.
yatala, QLD / Postage Australia wide at buyers cost.
CONTACT:
PM, phone 0433 108 569
PICTURES:
cheers, andy
