Results 1 to 7 of 7
Thread: need help s/t 20v over fueling poor ventilation setup
    Aug 2010
    Tweed Heads
    Default need help s/t 20v over fueling poor ventilation setup
    i am having trouble with my 4age 20v silvertop it is over fueling and dumping fuel into the oil and idle is like a rotary but afm is fine and no other problems apparent, i have looked at the breathers on the throttle bodies and half of them are blocked and now i dont know where there meant to go or lead to, any help would be appreciated, pics below...
ID:	18880Click image for larger version.
ID:	18882Click image for larger version.
    West
    Post photos of what it all looks like, and give us some info on where things are or arent connected.
    Is the vac line to the fuel pressure reg connected? Injectors stuck open? PCV in place and not blocked?
    A little more info and some photos would help us get beyond guesswork.
    Aug 2010
    Tweed Heads
    pics uploaded theres 3 at the rear of the throttle bodies and 1 at the front.
    Aug 2010
    Tweed Heads
    help???
    Stern but now fucked off...
    May 2005
    Nick
    How about replying to LittleRedSpirit's post?
    He asked questions to help
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    injectors stuck open, filling cyclinders, plug get wet you sit there turning it over and over and over, get too much fuel, fuel sits in cyclinders seaps past rings
    i recently had this, injectors were stuck open, had like good 8 litres or so of petrol in my sump
    Aug 2010
    Tweed Heads
    injectors are fine and its only a little bit of fuel in the oil. i just want to get the brethers all hooked up to see if it makes a difference.
  1. BigPort 16V+ Quads - crankcase ventilation
    By GeeEss in forum Technical - Questions
    Last Post: 28th January 2012, 05:01 PM
  2. Blacktop 20v excessive fueling - Video Attached
    By Matt in forum Technical - Questions
    Last Post: 29th November 2011, 05:12 PM
  3. My poor old USDM Trueno
    By Eircamae86 in forum Offtopic Discussions
    Last Post: 9th March 2009, 07:23 PM
  4. > Fueling Problem
    By jason in forum Technical - Questions
    Last Post: 20th January 2007, 10:26 AM
  5. Poor quality products
    By hoyin3132 in forum General Topics (No Technical Questions)
    Last Post: 23rd January 2006, 09:51 PM
