Results 1 to 4 of 4
Thread: 20v help
    Member blakey's Avatar
    Apr 2010
    Central Coast
    Default 20v help
    So in the pic it looks like a fuel reg? not sure.
    But the hose isnt connected so im wondering if it should be.
    First pic is mine, second is googe image, but high lighted.
    Any help appreciated.
    Also on idle when starting cold, it has a very bad idle. If i dont keep the revs up(just like 1000) it will stall or idle real shakey then once its starting to warm up it balances out and is normal.
    Not sure if thats just the way it is.
    Running bt 20v with itbs.
    Cheers matt
    Veteran slide86's Avatar
    Huw
    Hills
    That is the fuel reg, and you certainly do need it.
    At the moment, your engine is running maximum fuel pressure all the time, even at idle and starting. I dare say that the cause of the rough running is due to the engine running very rich and flooding the engine when trying to start.
    Reconnect the vacuum line and you will need to get some EFI rated fuel hose to connect the reg to the fuel return line. Id also suggest getting some new spark plugs, those ones are prolly a little fouled from running so rich.
    Apr 2010
    Central Coast
    Thanks, why would it be off in the first place though?
    Its purposly been taken off and blocked.
    It starts first go, but just idles ruff when its cold.
    Ok
    Seamus
    Milton
    The only reasons it would've been taken off is because of ignorance, or it came off accidently, or the owner (or 'friend' of an owner) was a moron.
    Like slide86 said, you'll just be getting a bit too much fuel at idle with it unplugged.
    ^ Clicky clicky!
  1. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  2. Replies: 4
    Last Post: 12th September 2011, 12:12 PM
  3. Replies: 3
    Last Post: 17th March 2011, 12:47 AM
  4. WTB: 20v wiring loom or 20v injector, VVT & TPS plugs
    By HYPNTK in forum Cars or Parts Wanted
    Last Post: 13th March 2007, 09:20 PM
