Results 1 to 6 of 6
Thread: 20v ke70 wagon F/S QLD
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    Default 20v ke70 wagon F/S QLD
    Hi all, putting this ke70 up for sale.
    In all honesty i don't have the time or tools to finish it + I'm running out of room to store it so it has to go! I bought it a couple of months back with the intentions with finishing it but had to unexpectedly move house and now i got bugger all time to work on it with the new job.
    So its a 82 or 83 KE70 wagon high roof
    AE71 crossmember and pedalbox
    20v 4age motor with a t50 and clutch installed
    razorback ecu and hand controller
    extractors and 2 1/4 mandrel bent exhaust 1 cat, 2 resonators and 1 muffler on back
    xt130 struts and brakes
    bosch coils
    trumpets and sock filters
    pre pump and a bosch pump
    since i have had it i -
    made the exhaust, a very well made exhaust! uses mandrel bends, proper reducers going from 2 1/2 down to 2 1/4 after the cat, tucked under real tight so you will be able to go really low without scraping. However the back half has only been tacked together and will require welding up to finish. Also the rear muffler needs welding on, it cut into position and ready to weld on. It will also need a couple of hangers to be welded on.
    bought a second hand exceedy clutch and installed it aswell as the T50 and made a custom crossmember.
    made a brand new loom for the razorback ecu and wired it in all nice and neat, but the loom still needs 1 or 2 wired joined and a water temp plug wired up. Ive also prepped 3 relays for ign, fuel pump and fan. Loom is out of the car currently
    Cleaned up the engine bay wires and made it all nice and neat
    Made up a few water block off plates for the back and side of the head, you still need an outlet for under the quads. This can be had for $80 off SAM Q
    Things you will need to buy to finish it will be:
    surge stank - i have a pre pump and a bosch pump, just need a surge tank
    water outlet, as described above
    starter motor, theres a 20v starter there but it doesnt fit
    dizzy cover - can get this off SAM Q for $80
    missing 2 bolts that bolt the caliper onto the strut, wrecker job
    and it needs a tailshaft.
    The motor has a drain on it as it used to be turbo'd, if you wanted to go down this road it would be a simple job as the ecu supports a turbo application.
    So there is a few little things to finish but once completed this car will be some awsome fun.
    I paid $1600 for this not so long ago and I'm only chasing for what i paid for it.
    i cleaned the shit out of the box before putting it in
    this is a pic of the old loom
    this is my loom half done, its a bit more progressed i just don't have any recent pics
    The car is located in Ashgrove qld. If your interested ring the number, i will not respond to txt's
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
    Feb 2010
    Jordan
    there doesnt seem to be alot of interest, just tyre kickers so id consider parting it
    and the prices would be as follows:
    motor + quads $600
    T50 $250
    razorback ecu $250
    extractors + exhaust $250
    bosch coils $100
    ae71 crossmembers with all mounts $250
    XT130 struts $100
    fuel pumps $100
    trumpets $50
    ae71 pedal box $200
    shell $250
    so all up id be getting $2400 or you could take it all away for $1600
    Senior Member kyle unwin's Avatar
    Kyle
    Nerang
    This is rediculous! I wish this was for sale a month ago
    Feb 2010
    Jordan
    still have this
    Feb 2010
    Jordan
    sold sold sold
    Kyle
    Nerang
    Lucky person.
  1. KE70 with 20v 4AGE (QLD)
    By geki in forum Cars for Sale (Toyota Only)
    Last Post: 30th December 2012, 06:50 PM
  2. [QLD] KE70 Wagon ultimate daily/wet weather warrior 5 months rego
    By 4DRFRK in forum Cars for Sale (Toyota Only)
    Last Post: 21st August 2012, 12:43 AM
  3. [QLD] Legit Nanna KE70 slant front low top wagon $1250
    Last Post: 3rd July 2012, 01:25 AM
  4. BRIS: KE70 Wagon with 4age 20v ST Unfinished Project
    By sillycar_chick in forum Cars for Sale (Toyota Only)
    Last Post: 19th January 2011, 10:19 PM
  5. [QLD] KE70 ..20V SilverTop... Roof Racks :P
    By ROSCO2 in forum Cars for Sale (Toyota Only)
    Last Post: 10th June 2009, 10:32 PM
