Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: 86 hatch gas struts
  1. #21
    Senior Member stylz's Avatar
    Art
    Melb
    mehh, if your hatch gas struts are fucked just bend them abit. once the boots open they wont close on you untill you pull it down.
    presto job done and it doesnt cost you a cent!@
  2. #22
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I just carry a stick.
  3. #23
    Jay
    bumpaged on an old thread but how the hell do you get the struts off the mounts, tried hitting a block of wood to know the ball joint out of the strut but no go.
    also if anyone is trying to find the struts you can order them at supercheap auto as they have a supplier which carries them and very cheap too compared to manroe or gabriel struts whichare normal $60+ each
  4. #24
    Junior Member Wiggles's Avatar
    Andrew
    Newcastle
    There's a little clip on them. It's shaped a bit like a question mark, the straight part goes through a little hole in the socket, and the curved part hugs the outside.
    You need to lever the curved part around so it isn't touching the socket and then pull it straight towards the strut body.
    Sorry, it's a bit hard to explain without a pic. If you wiggle the clip around a bit, it should come off without too much effot.
    The other thing you can do is unscrew the balls off the body while they're still attached to the strut. Then you can get a better look at how it clips in (or just replace the balls)
    Good luck!
  5. #25
    Gone
    Joel
    Picton
    stick wins
  6. #26
    Andrew
    Newcastle
    Just smash the glass, you wont have to open it at all then.
  7. #27
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    struts tas jonny, his name is brian, should be able to sort you out with repair or replacement, tell him mark at birdwood motors told you to ring
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  8. #28
    john
    nsw
    liverpool
    arent they bolted in ??? a 14 open end or something should do the trick.
  9. #29
    Call the "Strutman" google him...he did mine
  10. #30
    Jay
    Thanks , know the ones that you are talking about, the new struts ive got have them but the old ones just seem to be a ball joint, might just unscrew the bolts from the hatch and then try to work it out that way.
    Rust is a way of life
  1. Gas Struts for HATCH
    By dave2221 in forum Technical - Questions
    Last Post: 16th September 2008, 07:11 PM
  2. AE86 HATCH GAS STRUTS
    By Matty AE86 in forum Car Parts For Sale
    Last Post: 1st June 2007, 11:54 PM
  3. gas struts for the hatch
    By kurtis in forum Cars or Parts Wanted
    Last Post: 22nd February 2007, 09:29 PM
  4. Installing Gas struts In Bonnet
    By fozz in forum Technical - Questions
    Last Post: 6th August 2006, 03:12 AM
  5. Hatch gas struts
    By ke70_sa in forum Technical - Questions
    Last Post: 1st November 2005, 03:21 PM
