Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 36 of 36
Thread: 86 hatch gas struts
  1. #31
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    the original toyta gas struts have no other way to remove them apart from undoing the ball joint from the body..
    you will need a 12mm spanner for this, its needs to be slim and good quality, otherwise you will have trouble and round them off like jonny
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  2. #32
    Jonathan
    I ended up getting new ones for AE82 liftback. ML4320 Monroe.
  3. #33
    Veteran timbo's Avatar
    Tim?
    Wild West
    what was the price on those? im sick of using my head to hold up my hatch...
  4. #34
    Jay
    You can get AE86 specific ones from Super cheap auto, thats where I got mine, struts australia is the company that make them $30 each strut
    Rust is a way of life
  5. #35
    Senior Member cbjaust's Avatar
    definately need a 12mm spanner to get the original struts out by unscrewing the ball joints.
    G & R Industrial Products in Collingwood can get you struts for about $35 each including ball joints (I bought two for my AE86 and two for my Commo for $150 all up) - ask for struts that are 595 to 600mm in length and 400nm pressure.
  6. #36
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    I have the same problem :-/ what did you do after you cut the ball off?
    Nevermind a single hex socket does the trick, blonde moment
  1. Gas Struts for HATCH
    By dave2221 in forum Technical - Questions
    Last Post: 16th September 2008, 07:11 PM
  2. AE86 HATCH GAS STRUTS
    By Matty AE86 in forum Car Parts For Sale
    Last Post: 1st June 2007, 11:54 PM
  3. gas struts for the hatch
    By kurtis in forum Cars or Parts Wanted
    Last Post: 22nd February 2007, 09:29 PM
  4. Installing Gas struts In Bonnet
    By fozz in forum Technical - Questions
    Last Post: 6th August 2006, 03:12 AM
  5. Hatch gas struts
    By ke70_sa in forum Technical - Questions
    Last Post: 1st November 2005, 03:21 PM
