Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 37
Thread: 86 Corona engine
  1. #21
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    dont think he would have the cash or ability to do so.
    if i was gonna bother with a corona its what id do but eh....
  2. #22
    Site Supporter Javal's Avatar
    Josho
    OK team, here we go.
    22R-E into ST141 is a harder conversion than most would think. You basically need an entire RT142 to strip and transfer over. Brake lines fouling on inlets means you have to change the master, which has different outlets, which means you have to change the lines, which means the bias block doesn't line up with the existing lines, fuel hardlines are different, so you have to change them, and your fuel pump... wah wah wah wah wah.
    3S would almost be easier.
  3. #23
    Veteran Konakid's Avatar
    Henry
    Eastern
    Ill probably turbo mine, or 3sgte.
    Beams even, would be the only N/A motor id consider.
    That said they do only weigh about 1150kg.
  4. #24
    Josho
    headshave, cam, carb and timing for trucktorque
  5. #25
    Senior Member stanzzza's Avatar
    stanza
    west
    no calivn, there was several things i made and never got around to installing them, The F series diff , the motor i built for it 2s-3s hybred aka 2sge, i had 3 w series's box lined up and could'nt make my mind up on which too install plus the count less hours spent experimenting not to mention the celica front end swap i never got around to finishing off the guards , ra65 front on a st141 corona .
    mind you i was the first if not one of the frist to drop an s13 front into a xt14x chassis, there wasnt much info let alone the small trend that there was these days with coronas.
    It was some what uncharted waters,
    Just becasue i dont talk about what every little thing i do on the internet forums or tell every one my little secrets dosnt mean i haven't got an aces up my sleeve.
    think befor you start running your mouth calvin.
  6. #26
    Henry
    Eastern
    22R is injected honey, mwa.
    I want revs also.
  7. #27
    Henry
    Eastern
    ...when no one else in Australia had.
    Props.
  8. #28
    Senior Member shinny's Avatar
    Liam
    that build up is dope
  9. #29
    Josho
    I've spent too much time on toymods with 22R-C hilux faggots.
  10. #30
    E-Famous (Remeber your roots)
    Go 7age or 3sge.
  1. WTD: Corona 2s-c Engine Syd
    By troublesome_7 in forum Cars or Parts Wanted
    Last Post: 26th January 2012, 05:21 PM
  2. Parts wanted to suit 86 corona
    By J.white in forum Cars or Parts Wanted
    Last Post: 11th October 2010, 11:00 PM
  3. inj 2.4l 22r corona engine and gear box
    By sly1 in forum Technical - Questions
    Last Post: 17th July 2009, 07:45 PM
  4. 86 Corona
    By shayne86 in forum Other Toyotas
    Last Post: 12th January 2009, 10:26 PM
Tags for this Thread
