Results 11 to 20 of 21
Thread: axle tramp yo
  1. #11
    No experience of datsuns, but with the 86 its always the trailing arm bushings, & dont replace them with expensive rose jointed arms if its for street use
  2. #12
    Calvin
    Kilsyth
    mm fair enough i just don't understand how it would cause tramp. wouldn't they help eliminate it being VERY stiff?
    if it is the shocks i'll totally buy them off you if you're not using them anymore
    T18 in the build
  3. #13
    Senior Member Simon-KE70's Avatar
    S
    dude, the shocks cannot extend any more as they are fully extended alreadsy, so when you dump the clutch the diff torques up and the diff starts tramping cause the shocks cant controll it.
  4. #14
    Calvin
    Kilsyth
    ah makes sense. thanks
    T18 in the build
  5. #15
    Veteran Beau's Avatar
    Beau
    I agree with Simon.
    But Re: Trailing arms. Trailing arms should be parrelle with the ground. (level ground) This therefore lets the trailing arms do what they should be doing. When you lower your car you loose this angle and this can create axel tramp. This can be fixed by running traction brackets.
  6. #16
    A
    Parky
    Ra60 rear shocks, bit longer, fairly stiff and cheap as=winna
  7. #17
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    i recken simon is on to something. it makes heaps of sense ill play around with some diffrent shocks and ride hights let you guys know how i go. thanks for all the input.
    my shockers might be for sale hokey. if this is the case there brand new to.
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
  8. #18
    Troy
    Gisborn
    hey yo i went out to my shed and cut half a coil of my springs now my shockers dont bottom out. no more tramp 10 kudos for simon.
  9. #19
    Calvin
    Kilsyth
    haha that was the best solution ever
    testing would have been fun too
    T18 in the build
  10. #20
    S
    haha sweet as!
    another way to retain those shocks and have more effective range of travel is to chuck the car on a hoist, undo the shocks, cut the shock mount off the lower platform on the diff and rotate it 180 degrees so the mount is higher instead of lower. then reweld back on.
  1. axle tramp? blah, more powah please.
    By RRX-007 in forum Technical - Questions
    Last Post: 27th August 2010, 12:35 PM
  2. axle tramp. best way to fix?
    By trueno_coupe in forum Technical - Questions
    Last Post: 13th March 2010, 08:33 PM
  3. THE ALL ABOUT: AXLE TRAMP, DIFF BOUNCE etc thread
    By DRFT in forum Technical - Questions
    Last Post: 13th March 2010, 07:14 PM
  4. Axle Tramp?
    By -=GOODY=- in forum Technical - Questions
    Last Post: 16th January 2008, 12:32 PM
