Page 8 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 71 to 80 of 178
Thread: JAE86 **PAINTED!!!**
  1. #71
    Oldschool Member
    Apr 2005
    looks great justin, shame to see it bailing to melboune for a year or so
  2. #72
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    nice looking 86, caint wait to c it with the new suspension in it.,
    bcos no offfence it looks funny, as the car hsas been fantastic built and put together, but it's still sitting normal
    good luck with the future plans (if theres anything left to do)
  3. #73
    Justin
    suspension went in today...
    so low....
    srcubs alot in the back tho.... might have to flare them out.
    101mm at lowest point
    so just legal
    I started the ball rolling...
    Not member #1 anymore
  4. #74
    Rob
    Moorabbin
    good to hear!
    does it just scrub on one side? maybe your panhard rod needs adjustment?
  5. #75
    Justin
    nah, i've had a play with that to get the axel centered...
    just sorting a few options now to stop the scrubing...
    car handles exactly how i want too... thanks david!
  6. #76
    Rob
    Moorabbin
    after all the bullshit i told you the suspension would be good! im glad it handles good!
    also you should run a 195/50/15 tyre, that should make it scrub less also...
  7. #77
    Oldschool Member
    Mar 2005
    use smaller tyres. on your 8 inch rear rim you should be using 185s or 195s.
    You'll find the response it gives you outweighs the slight drop in overall grip from running 205s or 225s.
    Also, take a hammer to your rear gaurds and beat the lip in - all done. If anything I rekon the 210mm springs are too high!
    post some new pics
  8. #78
    Oldschool Member
    Mar 2005
    I just looked at the pics again - more specifically at the tyres. Get some stretch in there! what are they like 205 front and something even bigger on the rear? Get some 195 on the front and 195 ont he rear, maybe even 185 if it till scrubs. Some tyre places wont like doing it, but I can promise you it makes the car feel a lot more sharp and focused, and is perfectly safe - in fact I dont think I have ever run a legal sized tyre on my old 86s. always 175s on 7's and 185s on 8's. Makes it look sweet, and gives it way more response.
    Also looking at your profile, looks like a 55? or possibly more?
    Should run no bigger than a 50 profile on a 15 inch tyre. Any bigger and you lose response.
  9. #79
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    oooo! Pics!
    Pretty sure hes running 195/50 on the front and 205/50 on the back.
    Oh yeah justin did you go 7kg fronts 6kg rears?
  10. #80
    Justin
    yeah, ae71 neo is correct...
    i am putting 195s on the rear this morning to see if that helps... and maybe a bit of flare...
  1. Replies: 12
    Last Post: 8th July 2008, 01:12 AM
  2. Replies: 7
    Last Post: 19th February 2008, 05:39 AM
