Sorting out the wiring for the pump will be my next step.
Had to hacksaw a fair bit off and bend it here and there to get it to sit where it needed to, a few test fits and I made a trip to get some hose and clamps from the local auto spares shop..
Why hesitate when you can accelerate???
Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
whats with the tampo-ooh my bad
this thread is gr8 for the diy stuff kudos
Picked up a VL in-tank lifter pump setup from the wreckers today for the wiring setup ($55 later). Decided against running normal wire inside as I don't know how long it would last before the petrol chewed it away. An auto sparky I talked to said the same thing I was thinking, use the wiring out of another in-tank setup.
Can drill a hole in my setup and seal the wiring connector in, should be fairly easy..
Connectors for the lifter pump are already crimped and properly insulated, going to save a lot of mucking around..
nicely done![]()
Drilled the hole through the top of the old setup for the wiring connector to go though..
Underside shot of where I drilled the hole for the wiring connector to go
Wiring connector installed and wired up, Assembly is ready to go in the tank now![]()
