Page 7 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 61 to 70 of 132
Thread: Sound deadening removal
    Veteran slydar's Avatar
    Dimitri
    (Brett typing) Yeah l used the heat gun and scrapper too, too one night and a little of the next morning.
    You can speed the process up bu putting kero or petrol in a spray bottle and giving it a spray every know and then a couple of times a day a few weeks in advance, helps disolve and loosen it, just be sure to let the petrol evaporate well entruly before using the heat gun.
    Some one said that they did theres and it came close to 37kgs, l would almost vouch for that, l did the entire car and it weighed 29kg mesured using bathroom scales
    anyway came out pretty well, quick sand and paint and heyhey baby
    78's
    wow... that looks nucking futs!
    Jun 2005
    shoit... shiney
    *right click... save as...*
    now i have a pic to go on for the cage setup in my car
    stuff those little bolt in cages... mmmm fat pipes haha
    GoldCoast
    i so with i had your car brett, well atleast the cage, im currently removing that shit outa my car, *i was pwned by swearing filter* me its so boaring. and shit not much room in the boot to do this.
    i used friggen hammer and scredriver, this scredriver is adjective bit adn strong, it was better than a shisel. didnt destroy all the paint and shit underneath.
    i also hade a leaky sufge tank in the back so fuel was on one side and that made it heaps easyer to get it off.
    by a heat gun,(it think i got one somewere) its just a gun looking then that you can change waht heat come ut of it, (has no flames)?
    thanks for ya help ben
    btw brett you still got your other sprinter, i herd you crashed it, is this true???
    GoldCoast
    waht do people do with that shit thats n the joins in the body, its like body filler kinda shit, leave it or bring it down the the moetel so it look good or what, there is alote of it around the front seatmounts.
    some one plz help me im currently up to this and im not sure what to do
    Ian
    NOR
    id leave it
    just primer and paint over the top
    doesnt turn out too bad
    GoldCoast
    what do you primer it with, i used turps to clean all the stick shit of but the paint doesnt stick to it . so waht should i use?
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    Turps is oily but removes sticky things well. So after cleaning the sticky stuff off with turps, you clean the turps of with metho. Leaves it clean and ready for paint.
    Scott
    Gympie
    I finished my buid a little while age, and urge you not to do the following.
    At the time i tried soaking with turps. good to soften it up, but using a pressure washer is not the best idea. sure i came off the foor in a hurry, but en ded up EVERYWHERE>
    in the end best meythod was to use paint scrapers when it was cold, this way there is not too much sh*t left behind
    The best thing you can do then is prime, use a 2-pac undercoat, after you clean al the mess up with wax and grease remover. As for the floor joints, i dug most of this out and used sikaflex to make it smooth, even did the corners so i can hose the inside of the car out.
    I painted the floor with 2-Pac industrial floor paint in metallic silver and it looks pimp. engine bay too. the best bit is thhis stuff is cheap and is really tough, i cant scratch it
    GoldCoast
    no scratching sounds good, i was only spraying the floor with that rust stop shit, im not painting tyhe hole inside untill i get my cage fitted. but yeah the paint would stick on the floor. went all strange
  1. WHY NOT TO REMOVE SOUND DEADENING
    By Rich_86 in forum General Topics (No Technical Questions)
    Last Post: 7th February 2008, 11:42 PM
  2. Sound deadening weight
    By D-limo in forum General Topics (No Technical Questions)
    Last Post: 20th January 2008, 03:24 PM
  3. sound deadening
    By haul in forum Technical - Questions
    Last Post: 18th March 2006, 11:55 AM
