Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 40 of 56
Thread: my ae86 levin.
  1. #31
    Oldschool Member
    Mar 2005
    thanks for the comments. must be a reflection on that gaurd.
  2. #32
    Oldschool Member
    Mar 2005
    yeah, my 60ft times were always that bad in it, but I think my ET was a little faster..
    Look at the speed compared to the charger and the time, you were only 7kph slower, but nearly 2 seconds in time... 7kph trap speed should be less ET gap than that....
    Get on to the LSD, or lock the bitch for now... it sucks so hard trying to find an LSD for Hachi's
    I found an option here in Japan, it involves using a handmade subframe and the rear suspension/diff from a 180SX.... good deal I reckon.... you can buy it here for about $3500SUD.. ehehhe
    Or you culd look at trying to fabricate one, I know of an engineer who would pass it..
  3. #33
    Ian
    NOR
    just get t series and buy a lsd
    dont be cheap
  4. #34
    Oldschool Member
    Apr 2005
    hot damn! that is some great work. what wheels and front bumper are those??
  5. #35
    Paul
    That looks so HOT man, I have a red one too and that looks mad
  6. #36
    Oldschool Member
    Apr 2005
    Even stranger is I have his old 4agze in my hachi but it's changed a little.
    Looks the goods! I'd like to know a bit more about the suspension on this car. Those look like t3 camber tops.
  7. #37
    Ian
    NOR
    hey dude u using the ca18 gbox?
    if so u got any pics of where u cut the hole for the shifter to go through?
  8. #38
    Oldschool Member
    Mar 2005
    upgarage: i'll take a pic tomoz, it is a few inches rearward of stock, if uwant to keep it in the same place you'll need an rb 20 box and swap you bell housing onto it.
    monkey: yes they're t3, i should put up a spec sheet? but its not that interesting i don't think.
  9. #39
    Oldschool Member
    Mar 2005
    i don't understand this bit? just to clarify on the slip on the left i backed off because i couldn't be bothered changin to 4th the one on the left i did hence the fast trap speed but what if i had of gone for it on the other run oh well next time should be low 13's maybe high 12's even, has the power for it now just to convert it to forward motion and hope i don't break anything. alternatively i may not go again
  10. #40
    Oldschool Member
    Mar 2005
    He's not cheap, he's running way too much power for a T-series diff....
    Jon, you should grab a Hliux rear-end... lots of chat about them on Toymods, they aren't too hard to convert and LSD of many types available.... plus some good ratios, which could be one reason for the cars strange times as well...
    That diff is out of a 2.6L four cyl.. I think it has tall ratios..
    The part about speed was that you have the MPH.. but not the ET... work on the 60ft time is needed... not that you didn't know that...
  1. Jdm Ae86 Levin Mudflaps + Jdm Levin Speedo Cluster
    Last Post: 23rd February 2012, 11:25 AM
  2. AE86 LEVIN
    By SSD20V in forum Cars for Sale (Toyota Only)
    Last Post: 21st August 2011, 06:37 PM
  3. Replies: 6
    Last Post: 23rd March 2009, 06:02 PM
  4. my Levin AE86
    By xdanielx in forum AE86 Owners Forums
    Last Post: 19th December 2005, 08:36 PM
