Why go mad cutting and welding when you can just flare them out? The only reason he's done that is to fix the rust that he had in the first place..
Here's an unique idea for increasing your offset if you wanted wider wheels on your AE86.
Doesn't look that hard either.
Why hesitate when you can accelerate???
Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
note, only flare your gaurds if your wheels are wide enough to fill them
nothing looks worse than big gaurds with wheels that dont fill them out
I started the ball rolling...
Not member #1 anymore
yep uglyness gauranteed if your rims aint PhAtt
I can't remane the topic on this forum.
I was going to rename it "rear quarter rust repairs".
Anyway here's a quick and easy way to increase your front guards offset![]()
topic has been renamed for you
