Toyota specify a slightly larger oil filter for the 4A-GE than the smallest one used on other 4A's. The engines oil pressure would be effected with the restriction of the oil filter, not the volume.
Don't use good synthetic in engine or gearbox till it is run in. You may have trouble changing gears otherwise.
