OK change of plans... thanks to OPTION1 im getting a JDM shell with a sunroof already stripped bare so a lot of parts will be needed.
the plan is to turn it into this...
So far the plans are (keep in mind this wont be street registered)...
Engine: 4AGZE
Oil Cooler with remote filter
FMIC
2.25 or 2.5 inch straight pipe from front to back
Pulley Kit
Internal Work
Cams
Fuel pump
Injectors
ECU
Suspension:
Tociko custom coilover setup front with Cusco Camber plates
Tociko rear adjustable dampers
Custom springs
Sway bars
Strut bars
Driveline:
T series rear end (drum to drum for now... might upgrade to s13 bits further down the track)
Kaaz 2way LSD
Lightened flywheel
HD Clutch
Body:
Completely gutted
1 fixed back and 1 recliner
Full race style cage
Custom gauge cluster (no dash)
Exterior:
Stock at first (custom kit later on with guards front and rear, custom bonnet and hatch as well as front and rear custom bars)
15 or 16inch Work EWING rims
Im estimating about 18months before it is fully ready to the way i want it...
Only thing i will do until i have all the other parts is the suspension... then i will start hitting the prac days and building it up from there.
Hoping to have the LSD and suspension in by about august...
So yeah... finally starting to happen and i cant friggin wait... ever since i got the taste for it in december at banzai its all i can think about
