Results 1 to 10 of 15
Thread: 4AC -> 4AGE
    Alex
    St Lucia
    Does anyone know if its a straight swap (apart from the wiring) from the 4AC to the 4AGE using the 4AC gearbox?? If not can you use the 4AGE head, internals etc. on the 4AC block? Thanks
    alex
    wa
    new north
    An engine change is always full of tricks, but the 4AC to 4AGE swap can be one of the simplest, depending which 4ag you start with. I reccommend visiting Bill Sherwoods site, as he has heaps of info on this.
    NO, you cannot swap the 4AG head onto a 4AC block.
    Sameul
    Bulleen
    4A-C block is not at strong as a 7rib 4AGE block. Don't be cheap just go buy a proper 4AGE
    Medicine_Man has a quick information guide on the swap on the rollaclub.com wiki
    Oldschool Member
    Mar 2005
    sorry man but you are wrong there. the 4A-C head will go onto the 4AGE block. i have a mate that has done this to his AE71.
    Nikos.
    Senior Member Medicine_Man's Avatar
    Justin
    North
    You will find you have problems lining up the timing belt and water pump etc etc..
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    Oldschool Member
    Mar 2005
    I also beg to differ: the 4ag head can bolt onto the 4ac bottom, but theres a smaller power gain.
    Yang
    Salisbury
    While we are on this subject, are the engine mounts for the 4ac the same as the 16v 4age?
    Sameul
    Bulleen
    Did you even bother reading this?
    Alex
    St Lucia
    The only reason I was wondering about using the 4AC block was to keep it simple and if the engine mounts & gearbox were different for the 2 blocks. Im planning to buy a 4AGE, or a wrecked corolla and put that motor in.
    From what ive read it looks like I can just pull the 4AC out, leave the gearbox and drop the 4AGE in ya?
    Senior Member DRFTAE86's Avatar
    Ronald
    YES... just make sure there not cracked or worn.
  1. brissy>>>4ac bare motor with everything just not attached
    By phil-720 in forum Car Parts For Sale
    Last Post: 30th March 2011, 01:20 PM
  2. clutchs/flywheel 4ac -> 4age
    By blake. in forum Technical - Questions
    Last Post: 28th July 2009, 10:22 PM
  3. WTB: Everything needed to convert 4ac> 4age
    By Marlon in forum Cars or Parts Wanted
    Last Post: 18th August 2008, 08:43 AM
  4. 4ac -> 4age gearbox issues
    By yes02t in forum Technical - Questions
    Last Post: 12th August 2008, 11:15 AM
  5. 4ac -> 4age engine swap
    Last Post: 15th February 2007, 11:02 PM
