If i'm wrong, some1 please correct me. I'm also new at the t-18 info, but this is what i've learnt.
As far as i know..... All T-18's only use early model LSD's (ZENKI).
And from what i've seen the differance between an early model t-18 and a late model is late models are more likely to have sway bar mounts (like mine)
If you get an early model ur gonna hav to cut the swaybar mounts off ur stock 86 rear axle and welded em on to the t-18 axle.
Also some early model t-18 centres can hav shit ratios like 3:9.... you should get 4:1. Or acceleration will suffer.
