Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Shaking in Wheel
    Yang
    Salisbury
    My steering wheel shakes when driving. I have near new tyres and have recently aligned and balanced the tyres at Quick Fit. What else could I try?
    Oldschool Member
    Apr 2005
    steering rack end, ball joints in tie rods, or maybe wheel nuts loose
    Yang
    Salisbury
    It's always been shaking since I bought it. Could it possibly be the wheel bearings? I also have a Quaife Quick Rack 2.5 installed on the vehicle.
    Ray
    S.East Melbourne
    maybe a small buckel in your wheel
    mine does it over 100
    Yang
    Salisbury
    Mine starts at about 50km and gets worse the faster I go but the roads around here are bad enough
    Yang
    Salisbury
    There doesn't seem to be any damage to the wheels either. Is there any way of testing to see if they are buckled?
    Oldschool Member
    Apr 2005
    not steering rack, the steering rack end, the inner rack end which connects to steering rack could be playing, what u do is just move ur steering left and right if u hear noises then something is playing up..
    Ian
    NOR
    easy to spot a buckled wheel when its off and on a balancing machine
    tyre shop would/should have told you it was buckled
    I had this problem with my first KE70 and also after I changed to RA28 struts on the second KE70, It may well be a suss wheel bearing, take the cap off the middle of the hub, take the split pin out, and tighten the thing a tiny bit, then spin the wheel to make sure it still spins freely enough, if it does, re-split pin it, cap it, and take it for a test drive, should fix your problem...
    Kev.
    Tom
    SOR
    It seem that steering wheel shaking at certain speed is a common problem in ae86. I have the same problem with my car it wasn't as bad when I first bought the car ie I can get up to 140-50kph then it would start to shake now it would start to shake at 100kph. Its damn annoying , anyway I will check the wheel bearing like phrostbyte said.
  1. Replies: 5
    Last Post: 18th April 2011, 03:56 PM
  2. 15x8 +20 borbet wheel question! dnt no much about wheel fitment...
    Last Post: 13th April 2011, 11:43 AM
  3. Trouble finding SSR MK3 wheel nuts? No tyre/wheel shop able to help so far.
    By ivandude in forum General Topics (No Technical Questions)
    Last Post: 3rd November 2010, 01:33 PM
  4. steering wheel, boss kit and slip on wheel spacers :) (SA)
    By robert84 in forum Car Parts For Sale
    Last Post: 2nd September 2010, 06:28 PM
  5. FS: Twin Cam Wheel + boss & Autotech Wheel
    By hitoriko in forum Car Parts For Sale
    Last Post: 29th May 2009, 04:49 PM
