I have a speedo cable for you. $20
does any body no if a ke71 speedo cable fits sprinter or if any one has sprinter one for sale because im driving by tacho at the moment and its getting pricey
I just changed mine over and used a KE71 cable. The only difference is where it plugs into the back of the instruments the KE cable has a metal bit you have to cut off so you can use the white plastic bit from the '86 cable. And the little right-angle bit where it plugs into the gearbox isnt on the KE speedo cable so you have to use the 86 one.
As long as you have a tool to cut the metal bit off (I used a grinder) its no trouble to swap.
yeh that angle bit is the bit i was missing but i got one now cheers to OIM-666
