Results 1 to 8 of 8
Thread: Need Rebuilding??
    Yang
    Salisbury
    I have the JDM 4AGE 16V in my AE86. If you take the oil cap off and look in you will see nothing but black shit every where. The spark plugs seem to foul really quick and the exhuast blows black shit out (see photo below) I don't know how many km's the engine has done. If i rebuilt the top (valve's, cams etc.) would it run better or am I better off changing the pistons aswell? Any ideas?
    Senior Member DRFTAE86's Avatar
    Ronald
    Mine does that a bit at start up (not as much oil as urs though).
    Same JDM 16v, unknown k's too! Its the price we pay.
    Jul 2005
    I thnk it needs a rebuild....
    While you are getting your head build, just put some new rings and bearings on your bottom as well.
    Your car will drive a lot better....
    How big is your exhaust? Is it a straight through? On my previous car, as the cannon would cool down it would create condinsation. Next time you start it up, it would spray the carbon build up as well as the water out. You will notice that the spray doesn't smell like oil and the black actually seperates itself from the water. As far as your plugs and oil, what type of plugs and oil are you using? If you find your fouling to quickly, try iridiums.
    Try to eliminate all the small things before you go ripping apart your block.
    Ronald
    Just grab a good 20v bottom end and bolt that on.
    Yang
    Salisbury
    It is 21/4" and mandrel bent.
    Mar 2005
    i had mine rebuilt top to bottom for $1500 from dads mate. i could arrange roughly same price if you want.
    -40 thou rebore
    -block and head shaved
    -new pistons, rings, bearings
    -head service.
    -top and bottom gaskets and seals (VRS kit)
    it was well worth it, after running in, its now a year old and doesnt even use oil while flat stick on a drift track.
    Paul
    Gold Coast
    Wink
    Sounds like the car just needs a good fcking tune. Check all the sensors are working ok. Blue smoke is bad. White smoke is bad. Black shit who cares. Drive it until it goes bang.
  1. Rebuilding LCA's
    By shawn_26 in forum Technical - Questions
    Last Post: 1st December 2009, 06:09 PM
  2. Rebuilding shocks
    By benzo in forum Adelaide & SA Events and Discussion
    Last Post: 16th October 2009, 11:34 AM
  3. Rebuilding 86
    By dtp05 in forum Cars or Parts Wanted
    Last Post: 18th September 2009, 12:31 PM
  4. rebuilding motor?
    By 86TRD in forum Offtopic Discussions
    Last Post: 5th August 2009, 12:45 AM
  5. rebuilding engine
    By NUMBER_33 in forum Technical - Questions
    Last Post: 22nd November 2007, 10:18 PM
