Ask 'funkymonkey' he works for J-spec...... he should hav sum idea.![]()
I am going to be checking out a 1984 JDM Levin, which is uncomplied, an i was wondering if there is anything that I should be looking for that will cause headaches if I try to comply it. From the info that i have on the car it seems relatively standard, but has got coil overs fitted to it. can I use the parts off of an Aussie sprinter to get it through, such as suspension bits, or won't they fit.
Also, does anyone know of a compliancing workshop in Adelaide that does cheap compliancing??
Any help would be greatly appreciated![]()
off the top of my head.
ADR seatbelts
Fuel filler cap
side intrusion bars
the rest will be under a safety certificate or your states equivelant?
Can things like the side intrusion bars and filler cap be fitted from an ADM sprinter??
You have to get new belts don't you? I remember hearing that second hand ones are Illegal. also, Japan would have stricter emissions requrements than Aus, to the emmissions gear on the car should be ok, does anyone know otherwise?
Shouldn't there be a website for this?
If there is, and u find it..... post it up (and maybe it can be a 'pinned' topic)
