Results 1 to 10 of 10
Thread: can you still use 4age's on the road
    Brad
    I have got a stocko sprinter, and a rwd 4age, i now want a 4age powered sprinter.
    i have heard a few rumors that the 4age's don't meet the Australian requirements anymore, is there any truth behind this
    the engine that i have got is the blue/black 95kw version,
    thanks brad
    in tas
    Yang
    Salisbury
    I doubt it. There don't have a turbo or supercharger so it will still pass the emissions test. As long as you have a mod plate it should be fine.
    Veteran slydar's Avatar
    Dimitri
    pft. man you dont even have to do that, most mechanics who do road worhty couldnt/wouldnt know its not ment to be there.
    but yeah you can do it legit for sure.the engine was available in australian delivered cars so its really no problem at all.
    78's
    Brad
    Yeah that was what i was hopeing the car is still registered so i wont have to chuck it over the pits i hope. just was wondering what the inscurance company would say
    bard
    Senior Member DRFTAE86's Avatar
    Ronald
    Alot of mechanics round here always check the engine number of the block with the number on the firewall.... But just say the 4ac blew up so you had to put in another engine. Worked for me.
    But after that you SHOULD take ur car to Vicroads (or watever it is u guys hav in ur state) and just get ur engine legally rego'd in ur car. Only cost a couple of bucks.
    Senior Member SPEEDCORE's Avatar
    I think someone has crossed up some info from the company PRB (the guys that make those Lotus 7 replica kits).
    I read about 6 months ago on their website that starting from a date in '05, that the 4A-GE would not be able to be used in them anymore, by laws imposed by the NSW RTA.
    Whether this extends to AE86's also is another question.
    Hope this helps... and not open a whole other can of worms for you guys.
    Mar 2005
    i would like to disagree if i may, the black/blue top engine is the JDM engine for the levin/ trueno and it is an imported motor. it therefore requires an engineering signatory for it to be street legal. i got done for it 12 hours after my conversion was done. the black/red top from the AE 82 is the aus spec motor
    but on a separate note, the NSW RTA website says that a replacement motor that is not the same as the OEM motor is classified as "owner certified" not requiring an engineering signatory if it is not larger in capacity by more than (i think) 10% of the original motors capacity.
    this means that a 4AC to 4AGE conversion should be legal provided it complies with emission/pollutions laws.
    but i reccomend getting it certified to save you any hassles with the boys in blue.
    Aug 2005
    What about a CA18det into sprinter. Will that need to be engineered?
    And is it legal?
    Mar 2005
    anything is legal if it is certified by an authorised automotive engineer.
    as for the CA18 turbo you would have to upgrade braking system to that of an S13 or better (bigger brake rotors, brake booster, calipers etc). some engineers may want a suspension upgrade and/or collapsable steering shaft from the s.wheel.
    your best bet is to locate the nearest engineer on the RTA website or in store list and give the dude a call and ask him anything you want.
    Aug 2005
    Thanks heaps
  1. My Brown Ke70 and the road to 4age goodness! :D
    By tetsujin in forum KE70 / AE71 Owners Forums
    Last Post: 2nd October 2008, 11:12 AM
  2. WTB :4AGE 16V Smallport RWD Header's/ Extractor's
    By csr in forum Cars or Parts Wanted
    Last Post: 1st October 2008, 07:34 PM
