hey guys, i'm sure i have signed up befor..but just incase..
my name is Mat or Matty..what ever you wanna call it..
this is my car, i know most of you have seen it around befor..
the mods are just a few simple things i have done myself..jokes..i've gone nuts..it used to be my daily driver..so things like cage, stripped interior were on hold till now..
Engine:
4AGZE map sensor version 10.44psi max
ported flowed head
bigport cams
.8mm cometic steel HG
TRD N2 spec headers, 2.25" mandril exhaust, high flow cat, 1 muffler
NPC 4 puck carbon clutch w/ TRD pressure plate
Custom made tube/finn front mount (PWR core), with 2" mandril piping
3SGE 58mm throttle body and machined S/C pipe
stupidly big 3 core nissan urvan radiator
Suspension/.brakes:
Adjustable coilovers on the front, w/ AE92 TRD yellow shocks
300lbs/" springs
new pads/rotors (slotted JDM ventilated rotors)
fully rebushed with superpro bushes
custom rear springs with KYB shocks from a commo ute
whiteline adjustable sway bars (yet to be fitted)
RA60 celica front lower control arms (5mm longer) (yet to be fitted)
Cusco Camber tops set at -4.5deg
TRD 2- way LSD with shortened (grinder) RA40 axles
front strut brace
rear strut brace to be welded into place soon..
Body work: full respray by Camerons Bodyworks
Toyota Super White II
JDM side skirts
TRD front diffuser/splitter
Rolled/flared as much as possible gaurds.
TRD drift wing
Wheels/tyres
15x7" 0 offset speedstar Zeros.. 2 pac bronze centres
195/50 R15 Nankang NS-II ultrasport all round
Interior
Nardi 3 spoke wheel
Razo gear knob
Blitz Lumi-drive 2 bar boost gauge
As Toyota made it
Matty
