Results 1 to 10 of 13
Thread: T18 parts to an aussie 86
    Alex
    St Lucia
    Ive been offered a rusty old T18 for free and was wondering if theres anything worth pulling off them ie. sway bars, suspension, engine?. I know the diffs are compatable but thats it. I dont know if it has an LSD but chances are not likely Im thinking otherwise ill be one happy camper .
    Ferny Grove
    only a rumour but apparantly gearboxes will bolt up to 4a's as long as you use the 4a bell housing, they are also supposed to be better geared ratio wise. I have seen one in the flesh and they look exactly the same. but don't quote me on that. but if it does fit tell all every one i told ya!!
    if its free take it the diffs alone can fetch $300
    if you do get it let us know if its got chrome bumpers cause i'll buy em off you
    Alex
    St Lucia
    Sounds like I might be getting it then. Ill have to check it out an see what its got, maybe on tuesday or wednesday. I hope its still there..
    Veteran slide86's Avatar
    Huw
    Hills
    get it man
    the diff itself it worth getting the whole car
    Oldschool Member
    May 2005
    tadd
    nsw
    bh
    aus
    what about the suspension?
    Jul 2005
    pull the front struts out, diff and gearbox, then advertise the rest as a rolling shell for $200
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    so the struts are the same? anyone confirm the gearbox?
    Jul 2005
    I reshelled my old T18 4AGE into a sprinter basically with everything Struts diff etc. same with gearbox, i used to have T18 box matched to a JDM AE86 bellhousing to my 4AGE in the T18, but someone else may confirm
    *edit i have no clue lol! seems there arent the same
    Rob
    Moorabbin
    struts are DIFFERENT
    when u try to run a power steering arm or ae86 rca...then u will know
    Jul 2005
    ah i see well they do fit anyway and work but as above not exactly the same
  1. Replies: 1
    Last Post: 11th March 2012, 09:08 PM
  2. T18 spring seat, Different to 86,71?
    Last Post: 6th February 2009, 09:39 AM
  3. aussie spec 86 mirrors wanted
    By SEXY 16 in forum Cars or Parts Wanted
    Last Post: 15th April 2008, 03:17 PM
  4. IS THE T18 T50 GBOX SAME AS THE 86
    By orangechargd86 in forum Technical - Questions
    Last Post: 13th September 2006, 03:37 PM
