no body knows ?
As the topic says will a t 292 diff out of a ra40 celica fit into a adm sprinter and further more will this diff housing accomodate a trd 2 way lsd ?
any help appreciated
Leandro
no body knows ?
mounts might be different and track is probably different too
as far as I know, the RA40 rear end is the same as the TA22 rear end. If this is the case, then the trailing arm mounts won't line up correctly. But you can use the gearset out of the centre to get a 4.1 gear ratio for your T series rear end. Also, probably better to put this in technical as you may get a better answer there.
Isn't the 't 292' diff out of the RA40, a T series diff.........Yes.
And the ADM sprinter diff is a S series diff...............Yes.
Will it fit............................................... ................ No.
(All of the above info are assumptions and should not be read at any point)
Actually a diff out of a T18 is a T-series and it fits.
But seriously as mentioned, straight fit, not quit but its possible.
Steve
Insert witty comment here....
