Results 1 to 5 of 5
Thread: T18 rear ends an gearboxes.
    Alex
    St Lucia
    Why are T18 rear ends better than stock aussie 86 ones? Is it just the diff ratios or is there somthing im missing.
    Also does anyone know whether the gearbox will bolt onto 4A? And will any of the struts change over?
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    You can chuck an aftermarket LSD in the t18 'T' series diff, you cant get anything for the stock spoonter 'S' series diff. Apparently the gearbox and struts fit too.
    Rob
    Moorabbin
    gear box is different, struts are p00, different steering arms etc
    Ferny Grove
    aftermarket LSD's will go into the t series diffs ( t18 and jdm AE86 )
    also i'm lead to believe the axles are thicker / Stronger
    i was told when i was looking for one that the brakes are bigger but to me they look exactly the same.
    truenosedan what is different about the t18 box they look the same as a t50? is it splines?
    Rob
    Moorabbin
    front brake on a t18 are smaller than ae86
    rear brakes are the same size, shoes are same etc
    23 spline axles
    t18 box is a t50, but has different splines
  1. Replies: 4
    Last Post: 20th September 2011, 10:15 PM
  2. Disc brake rear ends...Whats best..
    By --Redwork-- in forum Technical - Questions
    Last Post: 13th February 2009, 03:22 PM
  3. T18 rear ends
    By Instigator in forum Technical - Questions
    Last Post: 27th June 2008, 04:53 AM
  4. two t18 t50 gearboxes
    By dehneyke70 in forum Car Parts For Sale
    Last Post: 22nd January 2008, 07:50 PM
