i pulled my sender out opened the little box and bent the bit of wire to come back into contact with the reader, shes finally workin sweet took 5 minutes.![]()
now get off your ass and do it![]()
Pretty easy to change a fuel sender. Buy one from autobarn, unscrew the plastic coverpeice in your boot, unplug the sender, unscrew the sender, pull it out, replace it, screw it all back on...
yeah mines got the same prob, jumps all over the place
can anybody gimme directions on how to fix it??
like how to locate this fuel sender thing before i pull apart all the wrong things?
That would be helpful...however, i haven't even looked at it yet soi'm flying blind to begin with
diggin up an old post, my fuel guage does the same thing, pulled the thing out of the tank, am i surposto open up that lil box thing?? or is is the dangly wires im surposta mess with???
Far out, that sounds easy, have to give it a go. You can get the whole sender and fuel gauge from Autobarn for around $59.99 i think it was
I just ripped out my sensor, there is two wires, one with a black box on the end and the other one with a condensor looking thing on the end that has a wire going to it. What exactually am I mean't to do to get it working?
Its easy to know when to fill up, when you go around a corner hard (like you should in hachi life) and it surges it means its time to fill up.
