hi all....just curious as to whether anyone has used a 4agze inlet manifol and adapted the throttle body to bolt onto it.....i have just done it and am curious..
i done a lot of research and alot said they were bad.....i thought i would give it a go as toyota used them on the supercharged motors so if they were good enough for them then i will give it a go...doesnt cost me anything....
just curious as i havent seen anyone use them,
if you look closely under the throttle body you can see the 'adaptor plate' that i made from ally so that i can bolt the throttle body to the 4agze manifold....its a bit like a turbo adaptor plate....
