Results 1 to 10 of 42
Thread: shocks that fit
    Poh
    Bevo
    hi guys
    was wondering what a good alternative to which shocks fit in the rears of the sprinter, mine are worn..
    how much would it cost to re-sleeve (rebuild) them?
    even though its not worth it..
    but what about re-sleeving aftermarket shocks that are worn?
    Jul 2009
    i have temperarily used some KYB shocks that were ment for an RA40 Celica..if you have lowered springs..they are a good idea..because they are about 80mm shorter stroke than an AE86 item..and a bit stiffer in the valving..but for a bit more bound/rebound..i have heard to use a holden HQ 1 tonner rear shocks..about the same sorta free height as the RA40 one, but shit loads stiffer!
    Matty
    Yang
    Salisbury
    What's your budget? Super Cheap/AutObarn etc. sells a brand called Gabriel, I would recommend them, try to get yourself some Monroe's but nothing lower than that.
    Poh
    Bevo
    hey matty thanks again for the help, what springs did u match with the ra40's and how much lower were the springs?
    alan: how good are gabriel and whats the price range for a set of those...
    seriously anything beats the shocks and springs than the originals, feels like im driving noahs arc
    Jul 2009
    well i'm actually using RA40 factory spring at the moment..reset alot lower, they were reluctant to reset them as they said they were old and they only reset aftermarket springs..so i 2 pac blacked them..and used a brother P-touch to make up some lables that said AE86 in japanese he he he..they pretty damm stiff..i found this out because we were wrecking my old mans RA40..had a rebuilt 18R-G in it..but we put that in the tufflux..
    Matty
    Yang
    Salisbury
    If I remember ill try to get prices tomorrow for you.
    Yang
    Salisbury
    Got some prices (prices don't include freight and can vary from store to store)
    Monroe Shocks (Part No: 15-3143+) $99 a pair
    Gabirel Standard (Part No: 81498) $47 each
    Gabirel H/Duty (Part No: 69611) $54 each
    Whiteline Springs (71210) $149 a pair
    King Springs (STD or Low) $149 a pair
    Rob
    Moorabbin
    i wouldnt touch monroe or gabriel....
    kyb is minimum........
    Nick
    Qld
    Brisbane south
    Aus
    kyb, bilstein, tokico & koni if you go aftermarket.
    Jason
    Gold Coast
    suzuki seira front shocks sit well in the rear of lowered sprinters, very firm,
  1. Sprinter shocks to fit ra65 'rear'
    By Pandara65 in forum Technical - Questions
    Last Post: 19th February 2011, 11:05 AM
  2. who can fit
    By jdmke70kid in forum Cars or Parts Wanted
    Last Post: 18th August 2010, 06:44 PM
  3. wheels to fit
    By luke keen in forum Technical - Questions
    Last Post: 20th July 2009, 08:33 PM
  4. will any others fit?
    By ke_rolla_ in forum Technical - Questions
    Last Post: 24th March 2008, 08:53 PM
