i wish they were both 7.5" wide tho![]()
with 0 offset and +5![]()
shit i didn't realise they filled the guards so well!! maybe i should've bought them!!
they seem to fill the guards very well as is bro!! are you sure they aren't wider than 6.5 or the offset is different, i had 15x7 + 15mm and they didn't fill the guards that well!! they look to be a zero offset.
put some pics up with all 4 rims on!!
i have Ra60 front discs soo... maybe they push out more.
The only pictures i have of the rims on are these. The rears fill em out nicely, but the fronts obviously need some flairage
Btw, these pics are without the engine in so the front is about an inch or so lower...
i am pretty sure they are around that offset. it isnt listed on the rims, but we measured it up and looks pretty much bout what i sayd.
The car is getting wired up today, but wont be starting becuase auspost decided it would be cool to keep my fuel pump over the 4 day weekend. When that gets here, unless theres something seriously wrong it should have her started.
rims look hot as, it must be the RA60 struts that change it. my -7mm 13x7's stuck out the guards that much at the front, so the struts are the only thing that could do it that i can think of
yea
The car is now wired up. Got Sam to do it, a fella recommended to me by mumblezz and andy86. The dudes a champ, did it really well...
lol and i conform again, i woulda had no chance in hell of doin that wiring my self hahaha
Car is now mostly waiting on fuel pump and i also need a map sensor as i didnt get one with my loom
I hope to have it running next weekish... fingers crossed lol
where did you get the hose made up for the cluch mine is too short but this is in an ae86
Call Slyder on these forums. He works for Anthony kellum.
0412 645 354
$45 inc postage i beleive.
... Getting a map sensor wired in tonight and just putting my fuel pump in... thats about it thats needed.
Does anyone know where you can get the braces that go between the plenum (Rwd is different to fwd) and the engine mount.
Also, what is it off? do u actually have to find a Rwd 4age to get one of these braces?
I tryed a toyota wreckers but no luck.
Also, i need a muffler like this week if anyone reads this..
ok... well turns out my fuel line that i originally put in now has to be replaced. I used a 10mm that was to be used for a oil cooler, however i decided the fuel line should have priority.
i now found out that i need a 7.5mm line in order to correctly fit the fuel pump
The map sensor is also in thats to sam.
So its just the feeder line that needs to be connected inc, the fuel pump and filter. then i just need to fill the tank up with petty![]()
its gonna be cutting close, but ill be getting my exhaust done like the friday before the drift day. And i also need to get a wheel alignment to fix up the steering arms and to get my mk1's cleaned out a bit so i can actually get my wheel nuts in em lol
another post by me.... im a genuine forum ho huh... lol
all that is left now is to put in a fuel hose that im getting later tonight and the fuel filter.
Then just exhaust, clutch bleed and to adjust my steering arms... as the rack was replaced... im anyone has any spare knowledge on doing this, can u give me a heads ups as im not too knowledgable on it
oh and, put my rims on today... curtosy of dan from pro force engineering to clean em out for me
