Results 1 to 6 of 6
Thread: Injectors
    Oldschool Member
    Sep 2005
    What size injectors come with GZE's?
    I am going to try between 150-200RWKW so what do you think the duty cycle of the injectors would be with that power?
    What size injectors do you recommend, what brand and where do you suggest I should get them? Would I need to modify the fuel rail to fit them?
    I am going to be running maybe 1 bar of boost with the SC14.
    Sameul
    Bulleen
    GZE is 365cc from memory
    Good for 300 HP @ the flywheel at 80% duty cycle at standard fuel rail prssure
    Ian
    NOR
    could also try 7mgte injectors
    Oldschool Member
    Sep 2005
    What size are they?
    Do they bolt straight on to the fuel rail?
    Will I need to get a fuel pressure regulator if I change injectors?
    Oldschool Member
    Apr 2005
    150rwkw is the upper limits of gze injectors.
    RE: 7mgte injectors.
    They are 440cc
    They bolt into the gze fuel rail
    You wont need a new FPR but you will need a new ecu or piggy chip/signal bender
    Oldschool Member
    Sep 2005
    With that much power I was going to get a new ECU anyway. What do you think the duty cycle of the 7M injectors would be at 200rwkw?
    Also what ECU do you suggest?
  1. Replies: 0
    Last Post: 2nd May 2010, 04:13 PM
  2. 7mgte injectors, bigport and smallport injectors
    By Rich_86 in forum Car Parts For Sale
    Last Post: 13th March 2008, 09:22 PM
  3. SARD Injectors 534cc Part number 63501 (4 Injectors)
    By gasit in forum Car Parts For Sale
    Last Post: 13th December 2007, 10:41 PM
  4. Injectors
    By Cerby in forum Technical - Questions
    Last Post: 8th November 2007, 01:00 PM
  5. everything but injectors
    By Gilly in forum Technical - Questions
    Last Post: 8th March 2007, 01:03 PM
