Results 1 to 10 of 18
Thread: Trying to connect the horn
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Hey fella's, the horn in my car came not working and seeing as i probly need it to work to be registered i decided to take apart the steering wheel bit.
    unfortunately i only got this far:
    i have removed the steering wheel and the nut that is inside the wheel adapter, however i have no idea how to contioue to take the adapter off from there.
    Does anyone know what i have to do to get that off?
    The wheel is a momo sport wheel. When i took the horn buttone off the wiring that was connected to the button wasnt connected further on as you can see here:
    Does that mean that wiring is fuked? or can it just be reattached to the connection to the horn?
    any help would be greatly appreciated
    thanks
    Grant
    Sep 2005
    doesnt it just plug into or connect to that wire or whatever it is stickiong out of that hole inside the boss kit
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    bolt the steering wheel back onto adaptor, put the bolt back on 1 or 2 turns, and tap the steering wheel backwards off the shaft, sometimes needs a bit of force.
    Make sure you leave the bolt on, i've been stupid enough to cop a steering wheel in the face twice now
    Grant
    Gold Coast
    so what... the adapter should just pull off? is that what your saying?
    and matticus, thanks, but the wire connected to the horn button looks as if its been cut or something... so i dont think it will just plug in
    heres what the horn button looks like close up:
    Steve
    Padstow
    yep, will just pop off.
    The adptor just slides onto the splines you see and the bolt holds it on.
    Grant
    Gold Coast
    so when im trying to remove the adapter... should i keep that bolt off thats on the inside of the adapter
    alex
    wa
    new north
    Toy sprinta is saying just put the big centre nut on a turn or two, so hen the wheel comes loose, it doesnt come all the way off and smakc you in the head. You sometimes have to give it a real heave to get it off. If you have a bearing puller of some sort, you can use that, it will make it much easier.
    PS, Toy Sprinta, once is an accident, twice is forgetfull, if you do it a third time, you got probs buddy Just kidding.
    Grant
    Gold Coast
    Alright thanks for the info fellas, that helps me alot
    Lol
    Grant
    Gold Coast
    ok, stratch what i last said on this post.
    I have managed to get the adapter off... with an extreme amount of pulling, however, i now have what you see in the attached picture
    my guess would be that the button that i have circled in red is the horn button for the main steering wheel, however, this doesnt make the horn work.
    What do you think i should do...
    The connection for the horn could be completely focked... or it could be that something is not connected somewhere along the line.
    Is there anything you guys can recommend that i can do to get the horn working? or should i just get an auto electrician to get it working? Obviously id like to spare the expense if possible, but im not gonna take apart the whole dash to find a loose connection in a wire
    plus i really dont know much about electronics
    thanks for all your help so far people
    alex
    wa
    new north
    Basically what your horn button does is connect the horn -ve to ground (ie the steering shaft). To test weather everything still works, get a short peice of wire and touch it onto that bit circled in red in your pic, and the shaft. the horn should then go off.
  1. Where can I connect the fuel pump cable in a JDM efi tank?
    By Dave in forum Technical - Questions
    Last Post: 28th April 2011, 08:58 PM
  2. What's this connect to!!??
    By JDM-086 in forum Technical - Questions
    Last Post: 25th April 2011, 05:19 PM
  3. how to connect exhaust to jdm rwd manifold
    By anastasios in forum Technical - Questions
    Last Post: 2nd December 2007, 03:49 AM
  4. how to connect a safc2
    By deanoo in forum Technical - Questions
    Last Post: 19th November 2006, 11:39 PM
  5. what does this flange connect to?
    By AE86.cn in forum General Topics (No Technical Questions)
    Last Post: 2nd January 2006, 01:44 AM
