do what??
if your thinking of using it for your sprinter, it's pretty easy..there is a section of rubber fuel hose from the tank to the steel line..mount it in there, with a plastic fuel filter (normal inline carby fuel fliter) BEFORE the pump (this stops all that sludgey crap from the bottom of your 20+ yr old tank, also protect your pumps warrenty), join anything before the fuel pump with new fuel hose, and new good quality hose clamps, then anything after the fuel pump with EFI fuel hose..even if it is only 2 " long..you must use EFI fuel hose..mount the pump with a bracket from a coil..make sure you use plenty of rubber/foam insulation around the pump and bracket so you don't get much noise..connect up the wires to your existing pump wires..and your set!
Matty
