Results 1 to 10 of 20
Thread: 4age conversion
    Hey,
    Its time for me to start doing up my 86. First step is a 4age. I'm sure quite a few of you have done this before and if you can help me in any way that would be great
    Firstly, what type of 4age would you recommend? Big port, small port?
    And sould I buy a FWD and convert it or purchase a RWD setup?
    I've read the article on the toymods website about converting a FWD 4age and I think I should be able to manage (then again... hehe)
    Also reguarding the price of the engine, what prices have you paid and what is the average for a 4age ( I know price depends on a few things, I'm just after a rough idea so that I don't get ripped off)
    Also I've found a RWD 4age with gear box, and ecu for $1400, is that reasonable or a bit high??
    Thanks
    So many questions!!!
    Ok...
    Firstly, the big port is an easier swap because you can get the proper RWD inlet and exhaust manifold, so I guess it would be easier and cheaper to find a FWD AE82 4AGE and convert it to RWD, though the parts are becomeing a bit rare (ie water pump etc)
    $500 seems to be the going rate for a 4AGE big port, you might even find one with the ECU and loom
    $1400? If the G'box is genuine JDM and the Loom is comlete i'd say yes, but depending on the Kms (JDM boxes go for around the $600 to $700 mark by themselves) If the 4AGE is already in RWD format all you'd need to do is intergrate the Loom into your own and its done!!!
    (Not forgetting the fuel system of course)
    Jul 2009
    yeh i don't know why the JDM boxes go for so much..despite what people think..there the same as an ADM box, aside from the bellhousing..that just puts the clutch slave on the other side..which will require a modified clutch line in your case then..not hard..but extra work for no gain..just use your stock T-50..get it rebuilt..$3-$500 depending where you go /who you know, thats new bearings, syncros, and seals..
    i'm building my smallport 4AGE from ground up..check my thread in tech section..should be ready in about a week..
    Jul 2009
    and about the water pumps...what do you mean rare?? you can get a repco brand one for about $80 and a toyota genuine one for about $110..it's just a AE86 4AC water pump..
    The ratios are slightly different between the Jap T50 and the ADM T50 (So I was told, also, I ment the rear water pump housing, doesn't the 16v fronts also have a different length?
    Sep 2005
    the ratios arent different, its the final gear on the lsd equipt sprinters that are different.
    Jul 2009
    correcting myself on that, the JDM water pump isn't identicle to the 4AC..but nothing a few hoses can't fix..
    i use a 4AC one on mine..i mean for the sake of a few cooling hoses..
    all toyota factory T-50's are the same across the board..
    the ratios are
    1st 3.587
    2nd 2.022
    3rd 1.384
    4th 1
    5th 0.861
    same ADM and JDM..unless someone has pulled the box apart and put in a TRD gear set or another aftermarket your box will have these ratios..if a JDM 86 'feels' closer together compared to an aussie one..it would be because of the different diff ratios..
    Matty
    Gary
    Hurstville
    The first step is definatly a 4age. Its not an 86 without this revy twin cam engine.
    Theres so much information out there on this conversion you will be able to do most of it yourself which is a huge cash money saving.
    I still cant believe that these engines still can be over $1000 complete! way overpriced if you asked me. for that price you can get complete engines and loom from a ae101 or ae111. Think about it, unless they have been rebuilt they have definatly done over a few hundred thousand KMS and i in my opinion will cost you double if you have to rebuild it.
    I bought my complete 1995 4age for $1000 flat. The fuel system was probably the greatest expense as i bought all new lift pumps, surge tank and main pump at just under $400.
    With forums like this and toymods there are heaps of enthusiasts that can help you (well most people are willing to help)
    Good luck
    Where can you buy a AE111 4AGE for a $1000?
    hey,
    Sorry I know it was a few questions hehe
    The engine and gear box are from a JDM sprinter from what the seller told me in an email, also the loom is complete. However I get the impression I may have to buy a few extra parts because the email says call for how much work/what parts you may need to buy I meant to call the seller today but didn't get around to it, I'll try to do it tomorrow.
    Thanks
  1. Replies: 3
    Last Post: 12th January 2012, 03:35 PM
  2. 4age conversion
    By ae13b in forum Technical - Questions
    Last Post: 15th January 2011, 11:59 PM
  3. Where to get a 4age conversion at?
    By superman_seven_x in forum Technical - Questions
    Last Post: 13th July 2009, 12:23 AM
  4. 4age conversion help..
    By redsprinter in forum Technical - Questions
    Last Post: 7th August 2006, 08:39 PM
  5. 4age conversion
    By dr1ft-pig in forum General Topics (No Technical Questions)
    Last Post: 4th November 2005, 07:53 AM
