sweet video
awaits pics and specs
big ups to the following for footage.
Ryan (Sleeper)
Dave (white S13)
Inark
soundtrack is a bit wack. its some Jpop stuff thanks to Gojira![]()
was bored, chucked some footage together, only one clip here is of the car turbo everything else is all NA.
need more footage ey.
i got some more pics and specs, coming soon .
car prob wont be blue for much longer...
sweet video
nice vid.
the music is okay. its 1000x better than dance/techon crap that is normally with those videos.
i reckon no music is the best though, i want to hear the cars![]()
heres a phat pic![]()
Specs are pretty much like this
Chassis:
Fully seam welded with structual support added in known weak areas, rear suspension points braced and welded
rear seat brace with harness mounts
Suspension:
AE86 struts cut down 120mm with coilover sleve kit welded on, SW20 REAR cusco inserts fitted along with a 10kg/mm spring, S13 Tein Cambertops, Sigma lower control arms modified with rosejoints, crossmember pick up point modified to lower roll center, Castor rods modified to allow more castor.
current specs are 4.5 degrees neg camber, 8 degrees castor and 1mm total toe out.
Rear susp consists of Kai Power 5 link adjustable rose jointed rear end, lower arms standard length and top arms are 5mm longer to give more grip. 8 kg/mm Cusco springs with approx 200 mm free height, TRD blue 8 way adjustable shocks. 18mm whiteline sway bar with nolathane bushes all round.
Drivetrain
Silvertop 20V 4age with microtech LTX8 ecu, Custom turbo manifold supplied by Raceflo, T25G turbo, dump pipe made by me, Hybrid cooler, custom inlet plenum made by me to feed boost into the existing quad throttles. 1jz injectors, Exedy HD 4 puck clutch, W55 gearbox, Custom tailshaft with T18 rear end, TRD 2 way lsd with 4.1 ratio.
Assorted
random wheels from 13's 14's and 15's, Paint job done by me, front and rear gaurds handflared by me, body is an extra 40 mm wider each side. Sparco seat, TRS 4 point harness, Omori gauges. Etc etc.
I remember you were trying to design a paint scheme. Anything finalised with that?
nothing eventuated with a paint scheme as i may as well try and encorporate a sponsor as part of the future scheme.
daily is a shitty AE82, might be "upgrading" to a twinky ae92 soon.
That's a big pic, looks nice though
