Results 1 to 5 of 5
Thread: altenator brackets for a 4age
    Veteran driftism's Avatar
    Andrew
    Watsoia
    what can i use to keep the altenator on the original 4ac (exhaust) side?
    I've got a bottom one, which was the original 4ac bracket, but the top one doesn't work....
    what have you all used?
    Rob
    Moorabbin
    one of a jap sprinter
    Andrew
    Watsoia
    they can't be easy to find though.... should i try and modify my 4AC ones...
    yep both of my 4ag'z have custom brackets cut weld grind sweet
    Jul 2009
    so what are you trying to do? if you want to run a GZE type altenator on the exhaust side..get an AE92 FWD 4AFE alt bracket..bolt on perfect..then just make a bit of a swing arm for the tension..simple..
    if your in brissy you can buy my old setup off me, tensioner, brackets, and even a spare GZE (pruple lable) altenator! i'll even give you the belt!
    for RWD setup an AE82 FWD alt bracket is on the lower intake side..same as a JDM one..actually, i'm pretty sure it is a JDM one
  1. 4AGE Altenator in ADM AE86
    By dtour in forum Technical - Questions
    Last Post: 14th October 2009, 12:06 AM
  2. jdm rwd altenator brackets
    By pen15 in forum Cars or Parts Wanted
    Last Post: 22nd May 2009, 02:34 PM
  3. 4AGE Alternator and Brackets
    By 4A-GE Power in forum Cars or Parts Wanted
    Last Post: 10th June 2008, 06:05 PM
  4. Any interest in low-mount altenator brackets?
    By Sam_Q in forum Technical - Questions
    Last Post: 24th January 2007, 12:55 AM
