does the gze still have the gze flywheel on it?
Ok, ive got a 4agze bigport out of an aw11 and a t50 off the back of my 4ac. But the problem is that the damn starter motor bulge on the bell housing is on the exhaust side (left).
What do i do? use the 4ac starter and backing plate or the gze starter modded to fit the 4ac backing plate.
And yair im confused as i thought it was supposed to be a straight fit!
my motors out of a aw11 and has a t5o box dunno y u have aproblem! what dosent fit about it?
Ok, the flywheel is now at the dump as its useless!
What doesnt fit is that the starters are on opisite sides. that is, the gze has it on the right while the t50 box is made to have them on the left. Any opiions?
Methinks the 4ac is supposed to be used along with the backing plate.
i dont see what the problem is?
bolt the gearbox to the motor
then try each starter motor?
if the gearbox wont bolt to the motor then u got a problem with something else. could be flywheel fouling on bellhousing.
also did you insert a spigot bearing into the crank of the gze
Use the 4ac starter.
the guy who did my engine pull the fwd motor's backing plate out but forgot the put the 4ac backing plate back in, so now I dun hav a backing plate..
The GZE flywheel shouldnt fit inside the T50 anyways. 4AC starter + GZE + T50 = Good...
DONT FORGET HTE FRIGGIN PILOT BEARING!!!!![]()
the bearing that comes with a clutch kit is for the throwout fork
