Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: gze + t50 dont match up
  1. #11
    Jul 2009
    pilot bearing - nsk 6001
  2. #12
    nsk (the brand) do not ask for a 6001 because they will give you an open bearing (trust me, where do I work???) ask for a 6001LLUC3 (Sealed bothsides with higher radial clearence) also known as a 6001-2RSC3 or 6001VVC)
    Spigot bearing= Pilot Bearing
    Throwout bearing= release bearing
    (Potato potato)
    You got it, and no, clutch kits dont come with the pilot bearing
  3. #13
    Veteran biggo's Avatar
    Nick
    Noosa
    Can some one clarify just what the pilot/spigot bearing really is, please. Because me being the cheap ass that i am, im trying to pull the THINGY that connets to the flywheel to the motor (you know what i mean). The reason for this i i want to use the 6 bolt 4ac flywheel in place of the 8 bolt ge/gze ones (talk about a grenade).
    And yes both of these thingies have bearings in them. So what am i looking at?
  4. #14
    Eddie
    It's exactly this thing...
    The OD of the bearing is 28mm so its pretty small as well.
    Eddie.
  5. #15
    You want to use the 6 bolt flywheel on the 8 hole crank???
    Ummm dude... NO!!!
    The pilot sits in the middle of the end of the crank and is veiwable from the middle of the flywheel.
  6. #16
    Ian
    NOR
    you def need a pilot bearing
    it supports the input shaft
    can lead to huge problems if you dont have one in there
  1. Replies: 1
    Last Post: 28th March 2012, 10:27 PM
  2. Wtd: 4age/gze & t50
    By WHITCHY in forum Cars or Parts Wanted
    Last Post: 28th January 2009, 01:34 AM
  3. 4A-GZE Flywheel into t50 Bellhousing??
    By AE86represent in forum Technical - Questions
    Last Post: 1st October 2006, 10:35 AM
  4. gze flywheel and clutch setup onto a 4agze (t50)
    By tom__86 in forum Technical - Questions
    Last Post: 25th September 2005, 03:04 AM
