Since the fuel tank would be JDM it probably will be a little tricky to get your hands onto.
hello forum!!
i want to one day do a 4A-GE conversion on my 86, i dont want to muck around with pumps and serge tanks and stuff...id like to do it propley. would it be worth finding an EFI fuel tank or just use the alternative pumps and stuff?
would an EFI fuel tank b expensive and hard to find?
anyone had the pleasure of putting 1 in...hard?![]()
thats what i thort...il just wait, im sure 1 will pop up if i keep regularly asken round!
nah man my 4ag never surges ay all good niga!
external pumps are ur friend..........
there is a few ways around this.
1# i just used a VN commohore tank, cut out the pump and baflle assembly and weld it into the AUS Spec tank, this is how mine has been done.
2# VL Commohore pump, lift pump is optional as too is a surge tank, but i hear there isnt much room under the hachi for this unless you put it in the engine bay.
3# find a JDM tank which doesnt really have baffles in it anyways, only some sort of storage pot, kind of a internal surge tank of sorts. Can be hard to find undamaged not to mention costly.
Personally i like the setup on my car, more then enough fuel, easy to swap and replace if need be.
Its also recommended that the fuel inlet line be replaced with something a little bigger (im using 10mm inlet) but i have heard that others use the AUS spec gear, i know of a 20v and a 100kw motor still using the shitty arse 6mm inlet, its your call i guess.
Good luck with it all.
Steve
Insert witty comment here....
jdm tank is great. very little surging
but it is not NEEDED
you can get away with a ext pump with a surgetank setp if you wanted.
I m thinking modifying my tank, but what is a bufful looks like?
looks like a bowl/pot
ill dig up my pic of the inside of a jdm tank
here u go
