Results 1 to 10 of 11
Thread: Cleaning Spark Plugs
    Yang
    Salisbury
    Is there any way you can clean spark plugs? Would Throttle Body/Carby Cleaner work?
    Yes but dont get too carried away with it, also try a (and becareful with it) a sharp blade (screwdriver if you have too) and a bit of sandpaper (120-240grit).
    Dont forget to regap sparkplug before you put it back in.
    Steve
    Insert witty comment here....
    Ian
    NOR
    if theyre a platinum plug you cant really clean them
    just replace theyre cheap as
    Yang
    Salisbury
    No, they are NDK Iridium. I'll try that tonight
    Jul 2009
    if there iridium i'd just hit them up with some carby cleaner and a pliastic wire brush..like a pot/pan srcubber thing..metal might hack them up
    alex
    wa
    new north
    If your stuck at the track with oiled up plugs and no cleaner, Here's a trick taught to me by a guy who was a mechanic on fighter aircraft in WW2 in the jungle in PNG.
    Stick the plug in something upside down (like in a little pile of dirt, sand etc). Pour a capfull of petrol into the plug, and light it. Let it all burn up til theres nothing left, then (after you clean the dirt, etc off the outside of the plug) you should be clean enough to run again. This wont necessarily get rid of a heap of carbon build up though.
    I shouldve asked, since the spark plugs are Iridium i wouldnt use sandpaper, carby cleaner and wire brush will work fine.
    But if the plugs are at the stage you feel need to clean them, then id replace them.
    Steve
    Yang
    Salisbury
    There only 4000km old but my valve stem seals must be shot or something
    Or maybe excess carbon build up due to rich fuel mixture, i know mine build up heaps to the point i get a bad idle and slight missfire if i dont clean em, but i only use the el-cheapo $18 for 4 plugs.
    Iridium shouldnt get dirty/nee dcleaning after only 4000kms.
    Steve
    Yang
    Salisbury
    I actually got tuned by Toyota about 4 months ago but they could of stuffed up anyway
  1. Spark plugs
    By Figgy in forum Technical - Questions
    Last Post: 21st April 2010, 10:20 PM
  2. spark plugs?
    By pen15 in forum Technical - Questions
    Last Post: 17th January 2010, 09:48 PM
  3. spark plugs
    By sprintdaddy in forum Technical - Questions
    Last Post: 4th May 2008, 02:43 PM
  4. Spark Plugs
    By stouty in forum Technical - Questions
    Last Post: 22nd November 2007, 05:46 PM
  5. what spark plugs do you use??
    By jeenyus in forum General Topics (No Technical Questions)
    Last Post: 20th April 2006, 12:12 PM
