by 4ws, you mean 4 wheel steering? or a typo for 4wd, and bodyroll?
if it's 4ws, beats me.
if it's 4wd, maybe you haven't adjusted your swaybar up tight enough?
Installed a Whiteline 20mm adjustable rear sway bar the other day, feels good during normal driving, but when pushed (cnr hard) i get the distinct feeling that the car has 4ws, well that what it feels like.
Could this just be the way it is, i mean the car handles 100% better (pretty damm good actually) and im not complaining, but it didnt think the rear end would feel so tight and loose at the same time.
Car also has Whiteline 27mm front sway bar and adjustable panhard rod also from Whiteline.
Anythoughts.
Steve
Insert witty comment here....
4ws? what are your rear end bushes like? old or new?
I think steve means it oversteers or rear steers when u lift off. which will happen with a stiffer rear
My hachi used to do that, as it would settle into the corner, and the G's would build, suddenly it would go into 4ws mode, and i would have to change my steering input.
Once i changed the bushings on the panhard rod, it was all fixed.
Drive the car without the rear sway bar for a week, then give us your opinion on which handles better.
^^ like crap
(what I'm doing atm)
its probably a slight amount of oversteer, not enough to break into a full slide or squeel the tyres just enough to make it feel like the rear is squirming around
The rear end feels all loose but it holds nice, well heaps better then the standard one anyways.
No rear sway bar, um nah, dont trust it
Every bush/collar anything to do with suspension isnt more then 18mths old. Except trailing arm bushes, maybe that it.
I dunno, just feels different thast all.
Anyone wanna test drive it for more, just to make sure im not going quer eye.
Maybe a wheel alignment is needed, cause i do notice it more when turning right.
Steve
Will do steve
