Surely that isn't how it is supposed to fit...
Yeah it seems there is something missing from these pics..
yes. definitly! there is ment to be a top capture plate.. like the machined billt plate at the top of these..
Isn't that what the red thing is?
yes, the easy way is to just cut the threads off flush with the bottom face of the camber top. the proper way would be to get some sort of spacer in there to get the spring hat to seat on the spherical bearing.
yeh it's supposed to have tapered bit that is smaller that the 4 studs..that just sits up inside..failing that..go down to BSC or CBC some sort of bearing place with some mesurements, and get some bearings and use them as spacers as previously said by ae86levint..
I went down to the fella's at Leda suspension, and thats exactly what they said. So any bearing shop should be able to help me?
Oops didnt see that. Im gonna go down to pine rivers bearings and see what they can do for me. Just gonna take the whole strut with me..
Do you think this custom little setup would work?
All put together...
